Screen not turning on
I am having a slimier problem mine was dropped once and is has not worked since, so there is little hope. when ever you plug it in all of the lights come on but the screen does not, also the fan comes on, you are still able to turn it off by holding the power button for a few seconds but it does not beep. when you unplug it it will turn off. please help!
~Jake
Is your backlight on?
Are the display cables plugged in properly?
You might also have a bad battery
try connecting to an external monitor?
does anything show up on the monitor?
Good luck trying to fix it :)
by Harjot Singh Share
