1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
User upgradable RAM for 11 Inch MacBook Air
Can I upgrade my 2 GB of RAM on my new (late 2010) 11 inch MacBook Air?
Score 1
Add a comment
Most Helpful Answer
Hi, According to the included link the ram on your machine can only be upgraded at time of purchase. Sorry.
http://www.everymac.com/systems/apple/ma...
Score 4
Add a comment
The SSD is secured by a T5 Torx screw. Do NOT try to unscrew it with a T6 or you will thread it. I almost did that since I read somewhere you need a T6 Torx screwdriver and this is INCORRECT. I bought a T5 since it wasn't in my toolkit and that is indeed the correct one. T5. Make note of this.
Score 1
Add a comment
It looks like they say SSD is not changeable but in reality it is. Maybe the same thing works with ram?
Add a comment
The ram is soldered to the motherboard. When you remove the SSD, which is secured with a t6 torx screw you can clearly see the memory modules. The modules are spread out on the actual logic board rather than a removable memory module.
The 2011 model moves the memory to a new location however it is still soldered directly to the logic board and is not removable.
Add a comment
yes you can easy
Add a comment
Add your answer
rickdesigndad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 19,978
