Fourth generation of the Toyota Pickup.
Wont idle when warm
Truck has a 22r. it runs fine until warm then it wont idle.
Add a comment
Chosen Solution
@lvec1 , Lou Vecchia, Possibly a stuck EGR valve or vacuum leak, although there are a lot of things that could cause idle problems, dirty carb., weak fuel pump, clogged filter, bad plugs, failing coil, etc. etc.. Links below may help trouble shoot your issue.
http://www.toyotanation.com/forum/80-89-...
http://4x4wire.com/forums/ubbthreads.php...
Score 2
1 Comment:
Ok Thanks. ill check the links.Going to work on it on Thursday.Ill post what i found. I have replaced the carb and checked for vacuum leaks.
by
Add a comment
my 2003 toyota truck will run but will not idle and dies
1 Comment:
new gas tank and fuel pump and new idle senor. new fuel filter
by
Add a comment
Add your answer
Lou Vecchia will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 23
All Time: 2,144
