Repair guides and support for motorcycles manufactured by Triumph Motor Company.
Why bike wont start
I have a 2013 thunder bird 1600cc sometimes starts with no problem, and other times power to gages and fule pump but when i hit the starter nothing not even a click?
Score 1
1 Comment
Check for correct gap of sparkplug (s) and proper plug size
by
Add a comment
1 Answer
Chosen Solution
@hectorpez ,Hector, That could be signs of a battery on it's way out or bad connection. Have battery tested, check all connections and wires for not being loose/corroded/damage in the starting circuit/on battery. See the link below as it discusses your issue. I have also attached a down loadable service manual at the 2nd link. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.triumphrat.net/thunderbird-tw...
https://trumpettouring.files.wordpress.c...
Score 3
Add a comment
Add your answer
Hector Perez will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 40
All Time: 3,328
