Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
3ds wont turn on
When I push down the button the blue light will fade on and off. That's it. This happened when I took the SD card out. Had homebrew on the SD card (I wanted custom backgrounds) and it was messing up so I was trying to fix it. It's at home charging now and I'll try to mess with it when I get home. The 3ds is about 6 years old had it since it got out. Maybe it's just old. Did I dun muff up my 3ds? Can it be fixed?
Uh oh now it won't charge. When I plug in the charger the orange light will stay on for a couple of seconds and then shut off.
Score 5
8 Comments
Did you ever install A9LH or CFW?
by
Yea I did. I followed the whole guide on 3ds.guide it worked perfectly for 2 days before I decided to mess with it more.
by
Try reinstalling the OS. And next time, don't install homebrew for a costom wallpaper.
by
Yea, lesson learned :p. How would I go about reinstalling OS on my 3ds?
by
Well, I couldn't say. Maybe @tronicsfix could help with that.
by
Show 3 more comments
Add a comment
Chosen Solution
Got it to work. Downloaded all the files from 3ds.guide onto SD card and put in ds while holding start. It's now letting me turn it on and off freely and its charging now. Although itsome not letting me turn it one without the SD card so still working on that
Score 3
7 Comments:
Your problem is you didn't go into FBI and move the arm9loaderhax.bin to the ctrnand
by
Now do a factory reset. You'll regret it if you don't! Also download Nintendo's repair tool from the store.
by
Good idea lol. Doing that now
Edit: ah crap charger is acting up again now. Even after reset.
Edit 2: if I take out the SD card ds won't turn on. Oh mannnnn
by
Same! My 3ds is apparently bricked, now i need to buy a new one. Maybe i should do the custom firmware again and do it correctly, and then put the sd card in. Will this work?
by
nigga what u downloaded
by
Show 2 more comments
Add a comment
This has happened to me. You shouldn't have done a reset. You need to follow 3ds.guide again and pay close attention to the steps after you install FBI and Luma. You should have copied the arm9loaderhax.bin from your sd to the ctrnand in FBI. But hey, who am I to tell you how to fix it? I've only fixed the problem on 5 different consoles. Take the answer or don't, but this is how I fixed mine.
Score 3
1 Comment:
Some one stoled my laptop and my SD card, my 3ds is not working
by
Add a comment
System reset. I'm telling you.
Score 2
3 Comments:
The reset didn't help at all :/ but I still have hope! But kinda feel like I'm beating a dead horse.
by
Did you download the repair tool?
by
@Bumbum Boop: ikr! its not working i feel annoyed and sad
by
Add a comment
This happened to me and i almost $@$* myself.
Luckily within about 10 seconds it powered on.
you should probs charge it.
1 Comment:
Dont work trust me
by
Add a comment
Just saying had problem used godmode script to copy la files to Ctr nand works flawless
Add a comment
sooo um also having this issue, following the updated instructions. right after b9stool is where it started doing this.
2 Comments:
Hello can someone on this web help me
by
I have a 3ds it wont turn on only the blue light is on and goes of when i turn it on
I intalled homebrew
Fbi and cfw
by
Add a comment
Add your answer
Bumbum Boop will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 41
All Time: 34,680
