The SKIL 4235 Jigsaw is a handheld power tool capable of cutting thin material such as plywood or plastic in a simple or complex planar design. The tool uses 120V AC input such as a household wall socket, to power a small blade, which can be dangerous if used incorrectly. Please consult the owners' manual for safety reminders.
Info regarding Carbon Brushes
I have a Skil 4200 H1 jigsaw which I've had a number of years and it has worked well.
The brushes need replacing but I cannot find anywhere that recognizes the model number. Can anyone Help me ? Would the Carbon brushes for the Skil 4235 be compatible ? If have to replace the jigsaw then I will but I am used to it's feel. It's like an old friend so desperately needed assistance.
Add a comment
Chosen Solution
Hi @ronkay ,
According to this website the brushes (ref # 10) are unavailable, however this is the part # for the brushes
2 610 376 874
According to this website the part number is obsolete and has been replaced by the following part # 2 610 967 197 and the part is available from them.
Alternatively if you search online using the new part number only you will get other suppliers of the part that might suit you better. Here is just one example. It is not a recommendation to use the seller, it is shown to give an idea of the price.
Hopefully this is of some help.
Score 2
Add a comment
@ronkay ,Ron, Link below may have replacement brush set, your original set #2 610 376 874 is obsolete, replaced by #2610967197. Good luck. I hope this helped you out, if so let me know by pressing the helpful button and select as solution.
http://www.ereplacementparts.com/carbonb...
Score 1
Add a comment
Add your answer
Ron Kemp will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 38
All Time: 769
