Informative guides for home coffee and espresso machines.
forever blinking in 3 fast 1 pause sequence
Hello!
my Krups Nespresso Inissia XN 100 machine after heating up keeps blinking with the following sequence: 3 fast 1 pause. The assistance said that there is an error in the electronics. Any suggestions rather than getting rid it of my poor Nespresso?
Score 1
4 Comments
Just spoke with Nespresso customer service: "The Essenza Mini will NOT work with an inverter." Oh well, back to the store... :(
by
1. Switch off at wall.
2. Turn on at wall.
3. Hold in the lungo(large cup) in for 5 seconds.
4. Wait for device to heat up.
5. If the lights do not flash then congratulations!
6. Enjoy coffee.
by
Genius! It worked.. the relief!
by
Francis, it didn't work on my DeLonghi inissia Nespresso, any idea how could I force its PCB to a hard reset?
by
Add a comment
Chosen Solution
@leoborni see if it is stuck in descale mode. Press both green lights for 3 secs and it should flashing at a slower rate. When they stop flashing it should be good to go.
Score 2
7 Comments:
Hello!
I checked and it is not in rescaling mode unfortunately.. the blinking sequence is different. I tried many time to press both bottons in different combinations of time and nothing happens :(
by
Okay lets see is we can find out more about your Krups.
by
What extra info can I give you? I'm desperate for an espresso in the morning T.T
by
trying to find a schematic to see what we can check
by
do I have to find a schematic? or are you..? sorry.. my English is what it is xD
by
Show 2 more comments
Add a comment
Most Helpful Answer
I’m my case it was the water container had leaked water into the hole underneath, I had descaled using vinegar then done all the cleaning and flushing only for it to start flashing continuously. I removed the water container dried it out and now all fine again, coffee back. It was in the hole not in the round gully that the container sits in. It worked for me hope it works for you.
Score 5
1 Comment:
What's happening if you press one button both flashing, and if you press both still doing the same
by
Add a comment
Just wanna ask, have any of you found the solution?
Add a comment
In my case, (after speaking with support) I was told the coffee maker doe not work with power from an inverter, like in a motor home.
Oh well. Returned it.
Add a comment
I just had the same problem, both lights would keep flashing 3 times. Tried pressing them both, pressing one,….
Nothing would work. Switched it off at the wall, waited 5 seconds and switched it back on…
Works perfectly now
1 Comment:
this worked temporarily, after a few days it failed again until permanently
by
Add a comment
In my case, after reading here, I removed the water container dried the hole put container back and turned it on and it worked fine.
3 Comments:
Also mine is a Krups Essenza Mini. And not Inissia.
by
Unplug your Essenza mini, then plug back in and press/hold lungo (Big cup) button for 5-7 seconds, the espresso (small cup) button will flash very fast 3 times, you have reset your machine and you are good to go. I just did it right now on a customer's machine after trying other solutions.
by
@furqanshafi Unplug your Essenza mini, then plug back in and press/hold lungo (Big cup) button for 5-7 seconds, the espresso (small cup) button will flash very fast 3 times, you have reset your machine and you are good to go. I just did it right now on a customer's machine after trying other solutions.
by
Add a comment
Add your answer
Leo will be eternally grateful.
Past 24 Hours: 14
Past 7 Days: 65
Past 30 Days: 309
All Time: 95,748
