Philips Marathon Bagless vacuum cleaner HomeCare with TriActive nozzle.
How to fix the cable rewinder
Hello,
The cable does not rewind completely when i press the botton. I would like to know how to fix this.
Thank you
Add a comment
1 Answer
Chosen Solution
@den23 , Den, Rewind spring may of detached from it's retainer. Use the link below(Philips Marathon Vacuum FC9202) service manual, to aid in disassembly of your vacuum to check/replace/repair the auto rewind spring/mechanism. Pg. 6 show's the mechanism in detail. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.manualslib.com/manual/108254...
Score 2
Add a comment
Add your answer
Den will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 38
All Time: 3,777
