Up to 20% off select tools
Repair guides and support for Canon's EOS Rebel XSi. This is a DSLR camera with a 12.2 MP sensor released in 2008. Also known as the EOS 450D and the EOS Kiss X2.
memory card is not working
memory card stopped working and will not capture pictures.
Add a comment
1 Answer
Jim -
On your Menu is a selection for Format. Find it and select it. That will give you an option to format your memory card. Do that; re-formatting a memory card usually solves access problems.
Russ
3 Comments:
When I open the format function, it is blank, there is no format function available. I get the reading, no card.
by Share
Jim - Have you tried a different memory card? -- Russ
by Share
Try removing the battery and let the camera stay without a battery for a few minutes. Then replace the battery and try again.
by Share
Add a comment
Add your answer
jimkerns1939 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 594
