hot water did not work
ruel hermino , Not much information supplied, make,model#, how old, did it ever work, does it still cool,etc.. If newer return under warranty for replacement/refund/repair. Check the power source for correct voltage cord for damage. If no warranty,unplug and disassemble check for internal blown fuse and or test limit switches and for any loose/burnt connections, if it has a board look for damaged/burnt components, etc.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
I own the Crystal Mountain “storm” model. I failed to find the hot water reset button in the rear. I’ve already tried to toggle the switch upfront with no luck. Any suggestion could be appreciated. Thx!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 1,137
