Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
3ds top screen not working
My top screen is black and the bottom touch screen works does anyone know why I am having this problem with my 3ds?
Score 8
Add a comment
Most Helpful Answer
@colhot ,colette , Maybe there's a problem with the cable connection to the top screen that's causing this, as the hinge moves it may have damaged cable/wire or loosened connection. Below 1st link is to disassembly guide for upper display to enable you to get inside device to check and clean all connections/reseat them and check for damage. Clean all the connections with a Qtip dampened with 90%+ Isopropyl Alcohol and reseat for good connection. If all connections,wire,etc look good the LCD likely faulty. If needed the 2nd link is for more guides for your device. The 3rd link is a replacement lower LCD display if needed which you can also do a search on for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Nintendo 3DS Upper LCD Replacement
Nintendo 3DS
Replace a broken or damaged LCD in the upper half of your Nintendo 3DS portable game console with this part. Image
Product
$34.99
Score 5
1 Comment:
I followed David Godson's guide for replacing abxy buttons but now the top screen won't work...
Please help.
by
Add a comment
I think it is a good question
Score 2
Add a comment
Is this expensive to fix??? I want my parents to fix it for my 13th b day!
Score 1
Add a comment
my top screen is black and i can’t see what am i doing when i play a game because my top screen dose not work do i need to replace it are something.
Score 1
Add a comment
Add your answer
colette will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 110
All Time: 27,501
