Up to 20% off select tools
Mini flashlight by Maglite that uses a single AAA battery.
Trouble opening ro replace battery
I am trying to open the bottom to replace the battery but it won't budge. Any suggestions?
Score 4
2 Comments
I have this problem too.
by Share
Same problem! I have tried everything to get the end cap off two pairs of pliers, the hairdryer thing some I cannot get it to budge!!
by Share
Add a comment
Most Helpful Answer
You can try heating the end with a hair dryer, this may help loosen the battery cap. It is possible that the battery has leaked and that is making the flashlight hard to open. The heat trick should help with that. If the battery has leaked, try cleaning the interior with vinegar and some cotton swabs.
Score 1
Add a comment
Maybe use some WD-40 and squirt in near it and let it soak down. Have you tried some pliers of grips to remove it?
2 Comments:
Heat the top battery cap while insulating the bottom then put the bottom into crushed ice using a pot holderto hold thw hot cap then use 2 pair of pliers or grips to open
by Share
I tried with 2 pairs of vise grips and it won't budge I have no idea what to do.
by Share
Add a comment
Add your answer
sethsmom0618 will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 126
All Time: 17,950
