The TI-84 Plus Silver Edition is a graphing calculator released in 2004. It includes a USB port, pre-loaded software, APPS, storage, and a removable front and back case.
Screen wont fully turn on
I turn on the screen and it works for a second then it turns back off. It does it all the time.
Its actualy a TI-84 Plus C Silver Edition i couldn't find it on the list of calculators to fix.
Add a comment
Chosen Solution
I found this maybe it will help. "
As a last result, try to reinstall the OS. To do this follow the steps below:
1) (TI-84 Plus CE only ) While holding the [2nd] [Del] keys down, press and release the RESET button on the back of the calculator. The message "Waiting... Please Install Calculator Software" should appear. At this point, it will be necessary to reinstall the calculator's operating system.
2) Connect the calculator to the computer and verify the USB cable is completely pushed into the TI-84 Plus CE using a standard A to mini B USB Cable and it is a tight fit. If it is not completely pushed in the computer will not detect it.
3) Open the TI Connect™ CE Software
4) Turn the calculator on. Make sure the calculator appears in the TI Connect CE™ Software Content Panel in the TI Connect CE ™ Software, click on “Actions” and then “Send OS.” (Warning: Do not disconnect the cable during a transfer.)
5) Navigate to the OS file you saved on your computer.
6) Click “Open".
Alternatively, you may drag and drop the OS file you saved on your computer from your computer to your calculator in the “Calculator Explorer” workspace.
Please Note: If the above steps do not work and you are using a TI-84 Plus CE please try the steps in Kbase#37116 if your calculator is unresponsive."
Score 4
5 Comments:
Thanks it worked
by
thank you so much
by
Mine says: Waiting...
Please install
operating
system now.
Then after a couple minutes, it says: ERROR! Press any key to turn unit off. Then turn unit back on. I do all that WITH the batteries installed, the USB cable connected and nothing happens. It just goes to those 2 screens. What the heck is going on with it???
by
Mr. Anonymous -- make sure you have the TI Connect software installed and the calculator is recognized by the computer/software when you plug it in and turn it on. That worked for me.
by
yo, this $@$* really worked for me. omg Thank you so much. You saved my fuking life. I would buy a new calculator if I can’t fix this $@$*, cause I have a math final exam tomorrow. One again thank you so much.
by
Add a comment
Add a comment
Add your answer
Heriberto pedroza will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 34
All Time: 28,958
