Up to 20% off select tools
The Sharp EL-531X is a scientific calculator produced by Sharp.
How can I fix it?
MY calculator won't turn off except after being left alone for a long period of time and the buttons aren't responding. Also it only displays 0=. and I've even tried restarting it many times.
Score 2
1 Comment
The calculator will display 1 no matter with the battery or not.
It stop working.
by Share
Add a comment
Chosen Solution
Hi,
Try replacing the battery and then resetting the calculator.
The EL-531X uses a LR-44 (or equivalent) battery
Here are two images that show what to do.
Battery Replacement
Reset
(click on images to enlarge for better viewing)
Score 2
1 Comment:
Hi. After changing battery and resetting, all the buttons still didn't work. Please help.
by Share
Add a comment
I had the same problem and managed to fix it by removing the battery and unscrewing and removing the back cover. That's it. I reckon that the issue happened because the "=" key connection was stuck, so uncovering the calculator might have "released" the connection. Hope this helps!
Add a comment
Add your answer
fahimakhan2 will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 47
All Time: 5,360
