Lightweight cordless vacuum sweeper for picking up crumbs and other small waste.
replace the swiffer vac circuit board?
can you buy or repair the swiffer vac control board?
Score 1
Add a comment
1 Answer
Chosen Solution
@uncledave11 , Dave, I did not find any one selling the replacement board. If you or a friend have some knowledge of using a DVOM and some familiarity with components on a board, capacitors, resistors and diodes you can test and some times visually see defect and replace parts. Below 1st link will get you inside the vacuum to the board I believe and the other 2 links are some tutorials on how to test and visual for failed components. Good luck.
Swiffer SweeperVac Battery Replacement (PG3000)
http://www.thomasnet.com/articles/automa...
https://www.lifewire.com/three-main-fail...
Score 1
1 Comment:
Is silver or cardboard side placed on the battery? Step 3 - photo look like silver side on battery. Step 5 - photo, unable to tell
by
Add a comment
Add your answer
dave will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 656
