Up to 20% off select tools
Repair information for the Garmin Vivoactive HR smartwatch. Released in February of 2016. Model number: 010-01605-03.
display broken / need replacement display
Hey everyone,
unfortunatly I crashed the display of my Gamin Vivoactive HR.
I called Garmin for a replacement and they told me its about 150€.
Is there any other possibility to replace the display by my own?
Buy the display seperatly anywhere ?
I am thankful for every help
Best regards,
Andreas
Score 5
1 Comment
Hey everyone,
Best regards,
Cesare
by Share
Add a comment
Most Helpful Answer
Hi Andreas,
I have a used display. Are you still interrested?
Score 2
7 Comments:
Is the used display still available?
by Share
Yes is still available
by Share
Hey there, I am also interrested. Could you please tell me if the Display is still available? You can also directly contact me via gerrit.puddig "@" conjin.de. thanks
by Share
Hi.
May I know ifthe display still available?
by Share
Leonidos didn't answer me. See my Question above...
by Share
Show 2 more comments
Add a comment
I had to open my Vivoactive HR because it wad died, what I saw it was water inside device :(
Now I know that it is no super easy way to open this Garmin.
1st. you have to unglued plastic part where buttons sits
2nd. using this hole (buttons whole) you should gently push screen using something like screw
  • be careful with electric tapes (there are few) it is easy to broken (tear) using only a little force
  • there is only 1 screw on button board
Maybe my photos will help anybody to repair this Garmin.
Score 1
Add a comment
So I have a vivoactive hr and yes a crack screen n unresponsive to touch too. Opened it up( direct from screen) and it wasn’t that hard too, but I really hope they start selling the screen so maybe one day I can replace it.
2 Comments:
How did you get the screen off? Trying to get it off without completely destroying the unit.
by Share
It’s being hold down by adhesive tape so use heat
by Share
Add a comment
You can buy a display there :
https://www.smitacn.com/lcd-screen-for-g...
Add a comment
Good to know for future, but in not much more you can buy used but working device :)
Add a comment
Add your answer
Andreas will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 44
All Time: 5,281
