Find repair and additional information for the GE Profile Refrigerator PGSS5RKZ, a bottom freezer model featuring an ice through-door and an automatic defrost system. This page covers information for model numbers matching the pattern PGSS5RKZ****.
No lights, nothing is on
Hi have a GE French door pgss5rkzss that we purchased about 8-9 years ago. Just recently our fridge would turn off completely and then turn back on a few hrs later. It happened again last evening and it still hasn't turned on. I scoured the internet to find answers and couldn't find anything. Our control panel isn't on either. I have no idea what it could be. I've seen people changed the motherboard and I've seen others highly advised not to do that unless it's burnt. Please help. I haven't pulled the board out yet but wanted to check everything else before I get to that point. Any advise will help. Thanks!!
1 Comment
Same issue, but after plugging back in…. Nothing. Cleaned condenser coil so no dust buildup now.
I was cleaning the fridge prior with doors open. After 20 min, the lights went out. Fridge completely shut off. Can’t get it back on. Checked outlet. It is fine.
by
Add a comment
Chosen Solution
Weird. I unplugged it for 20 secs and plugged it back and it came back on. Thanks!
Add a comment
First Check the outlet for power. This sounds to simple, but its usually the issue. If it doesn't work respond back.
Add a comment
Add your answer
Mike n will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 1,291
