Monochrome laser printer introduced in 2012. The printer is rated for 35 PPM and the first page comes out in 8 seconds. Depending on which model you own (a/n/dw/dn/dne), you will have different options and available features. Uses HP 80A/80X toner cartridges.
Will not turn on
The printer was working a few hours ago and then turned off. I have checked the power supply and cord to the printer and these are fine. The printer did come back on for about 45 seconds, after I removed the power cord and waited for a few minutes. However after that one time, it has not come back on even doing what was first tried. Is there a fuse on reset button inside? Thank you
1 Comment
Thank you! It is working again.
by
Add a comment
1 Answer
Chosen Solution
HP's suggestion is to turn the printer off for a half hour and turn it on. If it is still having problems then contact HP tech support. If this is still in warranty they may replace it.
Add a comment
Add your answer
Dale Devenport will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 16
All Time: 3,134
