Up to 20% off select tools
Use this repair guide to fix faulty parts in the Fujifilm FinePix S2980.
SD card will not insert
My SD card won't click into place in my camera like it use to, it won't lock in so I can't use the camera without the SD card
Add a comment
1 Answer
Most Helpful Answer
It may be problem with metal clips holding the SD card. Try to adjust them. I think camera has internal memory to place a few pictures without SD card.
Score 1
1 Comment:
Thank you for your advice. I’ll try adjusting the clips.
I’m not sure if the camera has a memory, but I’ll look in the owner’s manual.
Thanks again.
Mike
by Share
Add a comment
Add your answer
Emma will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 359
