A digital camera designed and manufactured by Sony in 2012. A 18.2 megapixel camera with Wi-Fi, GPS, and a memory card slot.
How to do a factory reset?
I've gone thru all the options on the Sony eSupport pages, it's a no go.
The power lite goes on, but nothing else works. The lil red "access lamp" (#25 in the manual, next to the sd card) flashes 2x then off, which may be an error code? The power lite goes off only if I remove the battery.
Add a comment
1 Answer
Chosen Solution
@paulieh01 this should work to reset your camera:
"The lil red "access lamp" (#25 in the manual, next to the sd card) flashes 2x then off" is an indicator for the memory card. You may have some problems with the card. Remove and/or replace it it and see if that changes anything.
Score 2
Add a comment
Add your answer
Paulie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 2,652
