Released April, 2014. CPU - Quad-core 2.3 GHz Krait 400, GPU - Adreno 330. Display - IPS LCD, 16M colors, 1080 x 1920 pixels, 5.2 inches. Internal memory - 16 GB, 3 GB RAM. Android OS, v4.4.2 (KitKat). D6502, D6503, D6543
Memory card slot broken?
Memory card slot broken and card popped out how can repair
Add a comment
1 Answer
Most Helpful Answer
khantdeepak you would have to replace the micro SD card reader. This will of course depend on the damage itself. You can always post some images of your damage with your question. That way we can see what you see. To post images use this guide. It is of course soldered to the logic board. You will have to have the right tools and knowledge to replace it. Check out this guide to remove the logic board. For the actual repair check out this video. Different model, same repair. The difficulty with this repair will be finding the right SD card reader. Something like this may work.
iFixit Image
Guide
Adding images to an existing question
Difficulty:
Very easy
2 - 5 minutes
Sony Xperia Z2 Logic Board Image
Guide
Sony Xperia Z2 Logic Board Replacement
Difficulty:
Moderate
15 - 25 minutes
Score 2
Add a comment
Add your answer
khantdeepak will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 588
