A depository for information on the topic of Plastics. To include restoration techniques such as De-Yellowing, Repairs, and Modification.
Motorcycle windshield tiny nicks in clear part
When dust or bugs hit the windshield, often there is a tiny dot or nick that reflects sunlight and looks like tiny stars. The only way I have heard about removing these nicks is to sand them out with very fine sandpaper, but I think there should be another way like some kind of wax or polishing fluid that will hide these blemishes.
Add a comment
Chosen Solution
I use this stuff it works great hand rub it in and buff it out when it dries. I do use a 2000 grit wet sandpaper to get out deep nicks and scratches and advise not to use high speed buffers ans they can heat and burn the plastic if your not careful. always keep the surface damp when sanding .I also use it on my helmet visor inside and out . Helps keep down down fog ups found that one out by accident ;-) Hope this helps
Score 3
Add a comment
Most Helpful Answer
@ronfix, Ron Creech , Try a head light polishing kit, most come with 3 or 4 grades of fine paper and polishing compound and a buffing pad to go on a drill. These kits can do wonders on clear plastic headlights imperfections and may work well for you. Warning to keep from melting plastic/burn, use slower buffing speed, keep moving and have a spritzer bottle handy to re-dampen buffing wheel when getting dry. Good luck.
https://www.youtube.com/watch?v=9apfwiCa...
https://www.walmart.com/ip/Meguiar-s-Hea...
Score 3
Add a comment
Add your answer
Ron Creech will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 23
All Time: 1,028
