Released in March 2013, identified by model number S500CA-SI50305T
How to boot from sad using USB boot windows 10
Hello,
I'm hoping to install an ssd in my laptop I'm planning on installing it completely blank then boot the laptop from a USB. Once I boot it from the USB will windows go right to the ssd or will I have to do something to save windows to the add so I can boot it up normally without the USB but instead from the ssd.
Thanks,
-Brad
Add a comment
1 Answer
Brad --
You must install Windows on the new SSD before it will boot. If this is a replacement, I suggest that you clone the old drive onto your SSD before installing. There is free software available on the web that will do that.
Good luck,
Russ
Add a comment
Add your answer
Brad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 367
