The Nokia 5800 XpressMusic is a Symbian-powered smartphone and portable entertainment device by Nokia.
Why showing offline on the screen
Show offline.
Setting could not take care of offline showing on the the screen. I cannot make call because it is asking for SIM. And sim is inside the phone
1 Comment
Hi,
Have you tried a different known working network compatible SIM card in your phone to see if it works OK?
Have you tried your SIM card in another known working network compatible phone to see if it works OK there?
What have you tried?
by
Add a comment
1 Answer
Chosen Solution
Switch it off, remove the sim and check that it's clean, now push it back in as far as it will go (use the stylus to help you).
Now switch back on.
If it asks you if you want to continue offline say no. If it doesn't ask and is still offline try selecting the "general" profile and see if it gives you any error messages.
If it still fails to work try another sim card to find out if it's the phone or your sim that is having a problem with that phone.
Score 2
Add a comment
Add your answer
Femi Awosanya will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,266
