A Turbosteam iron by Morphy Richards.
power problem with my iron
Suddenly my iron has stopped working. The light doesn't come on and also it does not heat up. Please help me.
Add a comment
1 Answer
Chosen Solution
dumevisenyo , Since it appears not to be coming on at all, try a different known working outlet, if not that the plug/power cord may be faulty or could be burnt off at connection in the iron. See the link below, tear down guide for your Iron so you can disassemble and test/check all wires/connections/switches/contacts/etc., visually and DVOM, to see if you can determine what has failed. Good luck.
Morphy Richards Iron Teardown
Score 3
Add a comment
Add your answer
dumevisenyo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 26
All Time: 6,418
