The Nikon COOLPIX S9700 is one of many cameras from Nikon's COOLPIX series. It boasts a 30x optical zoom and a 1080p resolution in a slim, compact body.
How do I remove the lens
I have a mark on the inside of the lens of my S9700. I almost looks like a chip, but I'm hoping not, and can't see how that could have occured. I know how to remove the outer most cover by twisting to the left with the lens extended, and can see that the lens glass itself is suspended by the rest of the structure. There are 3 screws which seem to be holding this assembly in place, but having removed them I still can't lift off the lens structure easily, and I don't want to force it too hard in case there is something more I have missed. Any help would be appreciated.
Add a comment
1 Answer
Most Helpful Answer
@davidsain , David, Posted a couple links below, I think if you posted at first link the owner may have a break down of lens he might send you, 2nd link are a few lens break downs/schematics that you can click on and check out the info. Good luck.
http://www.johncaz.net/blog/how-to-locat...
https://www.google.ca/search?q=Nikon+Coo...
Score 2
Add a comment
Add your answer
David Plant will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 1,363
