Broken Battery clip replacement
The tiny yellow clip that holds the battery in my Nikon J1 has broken. I would like to know how to fix it and what that part is offically called
This little plastic part could be actually bought for around $10 from a seller on eBay. But looks like it is out of stock now. The part number is 1K684-884.
Alternative solution: buy the extension grip Nikon GR-N2000 or its Chinese knock-offs available on AliExpress. They might help, as they should press strong enough against the battery door and keep the battery in place.
Thank you for your advice
I just replaced my battery catch , a part I ordered from AliExpress for £13. Patience is needed using watch makers tools took about 1 hour. After studying how and what to remove
cannot get to find any hints on the web, but it seems that you need to disassemble everything
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 38
All Time: 1,125
