Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
Upper LCD is Dark/Black
The Upper LCD screen is dark/black. I say Dark because if I have a powerful light shine in to it I can still see the game. This probably occurred due to rogue liquid (soda) finding it's way in to my console.
I would like to add this occurred after the top screen was flickering for a few minutes. Then the system shut off, and when I restarted it the top screen has been dark as it is now. Restarts don't change anything.
Everything else functions perfectly normal.
So I followed the Upper LCD Replacement guide, I haven't finished it yet though but everything is taken apart. My question is, should I replace the screen still as depicted in the guide? Or shouldn't there just be some grime (because soda) I can wipe/scrape away? I am incredibly, incredibly poor. I'm making less than my rent right now, which is why I ask. 10$ even is very important.
I found some grime I scraped away on the ribbon on step 18, dunno what that ribbon does though. Could be more elsewhere.
Guide I followed: Nintendo 3DS XL Upper LCD Display Replacement
From this question: How do I fix my black top screen on a 3ds xl?
Score 1
Add a comment
1 Answer
Get some rubbing alcohol and clean all the connectors and ribbons. Let it dry for 24 hours! Then plug everything back in and test. If that doesn't work, get a new lcd from aliexpress (10$), it will take a few weeks to come in, but then try that. If that doesn't work your motherboard is toast...
1 Comment:
I did this + used a cotton q-tip to clean the zif connector and wide upper lcd ribbon and unfortunately didn't work :(
But didn't wait 2min however. Will try leaving more time, thank you
by
Add a comment
Add your answer
Cary Hapeman will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 1,326
