Released alongside the AirPort Extreme base station, this hard drive equipped variant offers 802.11ac speed on a time capsule NAS.
Permanent overheated TC last 4 month
Hi!
My TC is permanent overheated las 4 months. I tried to clean it with service engineer, but overheat issue appears still as usual. Cooler works very loud, but engineer said it's ok.
I heard it is a bug of most TC devices and some people knows a tricks how fix it.
Can you give me advice what to do?
Score 3
Add a comment
Most Helpful Answer
I know of no tricks here ;-{ Most of the time the fan is clogged.
You may need a new fan if its always racing as that might be a bad tachometer. Did you damage the fan connector or cable during repair? As that too will cause it to race as the tach is not communicating to the thermal management circuit.
Score 2
Add a comment
I had this problem, solved it by a complete tear down of the time capsule, and clean the fan very thoroughly. Canned Air, WD 40 on the blades. Then removed the sticker on the underside of the fan and added a couple of drops of 123 oil.
It has been working good so far since the cleaning. But it has only been 24 hours.
Score 2
2 Comments:
Both the WD40 & 123 Oil you used will over time collect dust and gum up the fan again. The better solution is to just replace the fan and not use oil of any sort.
by
hi there, i am having permanent orange light even after replaced new fan, any other suggestion that i can try to fix this issue?
by
Add a comment
Fan needs to be replaced if the RPM are not showing.. and the temp sensor might also be damaged.
I just fixed one.
https://sites.google.com/site/lapastenag...
Add a comment
Add your answer
sergio.chaplygin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 32
All Time: 3,213
