Toyota's fifth generation Pickup
Tranny stuck in reverse
How to take it out of reverse
Add a comment
1 Answer
Chosen Solution
@jpnegron , Sergio Angulo , If manual transmission, try having some one rock the truck back and fourth while you try shifting out of reverse. If it does pop out your clutch/pressure plate/master/slave cylinder may be worn/faulty/ or have air in hydraulic system not allowing release. If it will just not come out of reverse suspect a damage/bent shift fork inside tranny. Good luck.
Score 4
Add a comment
Add your answer
Sergio Angulo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 515
