All variations of the HP G61 laptop.
usb ports do not work at all
the two usb ports on the right side do not work at all
Add a comment
1 Answer
Get into your device manager and scroll through all of your USB Controllers. The ones with a yellow triangle indicating issues means usually the driver(s) needs to be updated.
Or it refers to a hardware error.
I forgot to state: you could disable the power management on the USB hub. Windows tries to disable devices when not in use to save on power. As above, tree branch out the USB Controllers, root hub and right click properties. Tab Power Management and uncheck where it says allow PC to turn off device.
Save and restart your PC.
Also, they are probably USB 3.0.
Shaun
Add a comment
Add your answer
jstani4th will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 18
All Time: 445
