The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube and the Nintendo Wii, and to a more limited extent, the Nintendo Wii U and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
"A" button working like a turbo controller?
I bought a gamecube controller from china, and everything seems to work fine. But in some games that I have to press and hold the "A" button the videogame understands that I press and release and press again the button many times.
Has anyone seen anything like this? And there's someway to fix it?
Thanks!
Score 1
Add a comment
1 Answer
Most Helpful Answer
There could be a series of problems with this issue you're reporting. Since it's a knock off controller it could be:
  • Damage to the PCB during manufacturing.
  • A bad button indicator.
  • Some kind of liquid making a crossed connection.
Get a tri-wing driver, open up the device and inspect it. Clean up the area with rubbing alcohol, inspect the button and the pad it rests on and look over the cuircit board to see if there are broken traces or other signs of damage. If you're having any issues determining the problem. Take a few pictures and add them to this post to see if there is anything you may have overlooked.
Hopefully, we can get this controller working properly again. Good luck!
Score 1
Add a comment
Add your answer
Yuri Lelis will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 34
All Time: 615
