Up to 20% off select tools
The drone is a Wi-Fi capable and it's equipped with a built-in HD camera. It is used for taking pictures and filming. Model number: PF722000
Why does it say error (11)
Score 1
1 Comment:
I checked all my wires and it still didn't work any other causes for error code 11 for the bebop 2?
by Share
Add a comment
1 Answer
Error 11 is due to a disconnected motor. With an early production run of Bebops, some had issues with motors not being fully connected. Cables are just either unplugged or the snapped and broke. You can either contact Parrot about this or (riskier) attempt to disassemble the drone yourself on whichever motor may be out and fix the cable yourself.
1 Comment:
It's something else. Because I run all motor separately with a single esc an it works well no problem I think these hands over the prop safety feature causes this to happen if there is a way on the main board that u can discount the features it would work fauless
by Share
Add a comment
Add your answer
Virginiamckale@comcast.net will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 6,829
