First generation of Citroen's supermini car.
Reversing light comes on occasionally when breaking
Since having my reversing lights repaired at a garage, they come on occasionally when I break. Drivers behind me are worried! I can't recreate the fault when stationary tho. Help!
2 Comments
does the reverse light work when you have it in reverse gear??
by
Yep, reverse light works when in reverse gear and I can see it when it's stationary
by
Add a comment
1 Answer
Chosen Solution
Hi,
If the work was carried out recently to repair the reversing lights by a garage, there should be some sort of guarantee on their workmanship, provided by them, even if it is only for 30 days etc.
Take the car back to them and explain the problem and show them as well (hopefully the problem will happen when you do this) and ask them to check it out, as it is causing problems for you..
Score 2
Add a comment
Add your answer
sophie will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 10
Past 30 Days: 25
All Time: 445
