The Atari 2600 or Atari Video Computer System (VCS) is a video game console released in September 1977. The 2600 runs a MOS Technology 6507 CPU and uses ROM cartridges for storing games.
The screen seems dark
I just found my old 2600 in my garage, I cleaned it up and even fixed one of the controllers that was broken inside, so when I plug it in and turn it on the screen seems a lot darker than I remember it looking, what could cause this? everything else works fine.
3 Comments:
@kazman72 how did you connect it to your TV and what TV are you using?
by
I used the rca cable to the cable coax adapter method, I'm using a newer samsung hd tv.
by
Did you check your RF switch on the back of the console? And the tip of the cord that goes into the console? Sometimes it gets dirty over time and doesn't get a good connection. I would suggest unplugging everything the get a qtip with rubbing alcohol and cleaning the connector on the console and the end of the cord. That works for me.
by
Add a comment
1 Answer
Try checking the screen settings on your television. On my LG I can set different lighting settings for different inputs, and some cause the screen to appear darker than others. Each input on your television will have different pictureh modes so setting it on one input will not automatically transfer it over to another.
Add a comment
Add your answer
Jonathan Kazarian will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 27
All Time: 860
