Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
Touch ID not working after screen replacement
So I attempted to replace a broken screen on the iPad mini 4. I successfully replaced the screen and home button but then realized the Touch ID isn't working. Of course, after the fact, I read how this can happen. I removed the home key and replaced to new screen but a small cable tore and unsure what exactly it does and how to repair. I took a picture but unsure how to upload. It's a small square to the left of the home key.
Score 1
Add a comment
Chosen Solution
Based on your description (I don't see pictures), you tore the delicate home button connector, and unfortunately, there's no way to replace this and retain TouchID functionality. The only way to regain TouchID functionality is to get a paired logic board/home button assembly. For security reasons, each TouchID sensor is binded to a logic board during manufacturing, so you cannot replace one or the other without replacing both.
Score 1
3 Comments:
Even though the home button still works? Any idea how much that costs?
by
I believe that the home button uses POGO style contacts to make a connection, and that only TouchID data travels through the ribbon cable. iFixit does not have any replacement parts for this particular model of iPad, but it is not a cheap or easy repair (>$300).
by
Ah, okay. Thank you for your help!
by
Add a comment
Most Helpful Answer
This was torn off from the broken iPad
Score 1
Add a comment
Add your answer
Brenda will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 20
All Time: 5,491
