Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
My PS3 controller will not turn on at all?
My PS3 controller wont turn on - no red flashing lights - no response to being charged or reset. Also, when the controller used to work, I accidentally hit it - not hard - against my fan and then it sounded like something was broken inside of it.
Add a comment
Most Helpful Answer
find a set of star screwdrivers and open up the controller then detach the battery connector from the board of the controller then try connecting it with the usb to your console and do a reset on the pad it should work if it does probably your controller is dead
Score 1
8 Comments:
Ok will try thank you!
by
So am i pretty much just removing the battery
by
It did not work
by
then it should be a board issue
by
suggest u get another controller then
by
Show 3 more comments
Add a comment
Solved ! Get the same usb type cable with data support.. like printer cable so that your ps3 controller can be detected by laptop/PC . You will see the controller lights blinking the moment you insert in the PC (install the drivers first or win 8 which has pre-installed drivers for ps3 controller). Insert and remove couple of times the USB cable until your ps3 controller is able to start up (don't start playing immidealy let it charge first) ..then charge normally . I once tried this with dead iPod it worked and it worked with my PS3 controller too.
Add a comment
My ps 3 controller is not working not blinking light
Add a comment
Add your answer
SilverLordGamer512 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 30
All Time: 10,345
