GoPro’s seventh generation camera released in late 2012. Capable of recording 1080p30 video, waterproof to 197', and built-in Wi-Fi.
Automatically Shuts Off After A Few Minutes
My GoPro Hero 3 either doesn't turn on or it automatically shuts off after a few seconds or minutes. At first I thought that the battery had an issue so I bought two more batteries and made sure that they were all fully charged, and when I tried each of them the GoPro still it doesn't stay on. All other functions work without a hitch.
1 Comment
I have the exact same problem. It’s a brand new gopro. It’s supposed to give me at least 4 to 5 hours record time, I know this can be shortened if I’m using very fine record etc. I do find that after turning it on, I go out for a cycle and when I come back after 1 hour 30 minutes cycle & discover that my gopro has switched itself off During play back I discover that the go-pro had stopped recording as soon I went around the corner from my house. I’m presuming this is when it switched itself off. The batter is fully charged. Unfortunately, I have no way of removing the battery as it’s built-in to the unit & is rechargeable via USB. This is extremely frustrating as it was expensive enough & given todays society, where most people, not all, but most anyway, are in competition with each other to see who can be most hazards to cyclists/pedestrians. I was hoping that the gopro on my cycle helmet would serve as a unbiased witness in the unfortunate even that I have an accident involving another cyclist, car, or, pedestrian. It’s only serving as a useless piece of weight on my head at the minute. I’ve done all I can in the menu settings thinking I had set something up that causing it to switch itself off, but, from what I can see, there’s no reason for it to do so while there’s still plenty of power in the batter. I’m on limited funds, so I cannot afford the swanky sleek cycle helmet cams. I can’t afford hundreds to fork out on it.
by
Add a comment
Chosen Solution
Hey Dounia,
Did you by chance drop your GoPro? It looks like some of our community members have experienced a similar problem. You can read this thread for reference: It keeps turning off and on by itself.
Here are a few things you can try:
  • Check if the battery terminal where the + side of the battery is loose and if the spring tension is not holding the battery in place when inserted
  • Replace the battery doors if they are loose
  • Remove the SD card
  • Try a new SD card
  • Upgrade the firmware
  • Open the device and look for any loose connections
Score 3
Add a comment
This article might shed more light on the issue: https://www.linkedin.com/pulse/gopro-shu.... It outlines several potential causes for random shutdowns and includes practical tips to help troubleshoot or prevent them. Hopefully, one of the fixes mentioned there will get your GoPro back in working order.
Add a comment
Add your answer
Dounia will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 24
All Time: 9,527
