The 2013 edition of Razer's 14" ultralight gaming laptop. Released in July 2013 with the model numbers RZ09-01020 or RZ09-01021.
My screen is not working
When i switched on my laptop, the screen is malfunctioning as it splits into three different screen on the laptop. Is there a way to fix it myself?
Add a comment
1 Answer
Chosen Solution
@susu23 first you want to make sure that it is your LCD. Connect an external monitor and see what that shows. Should that show the same defect as your laptops LCD then you know that you are having a GPU (motherboard) issue. If the external shows a normal image, consider replacing your LCD. Take a look at this guide and this video. Combined you see how to remove and replace the LCD.
Score 1
Add a comment
Add your answer
Susu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 929
