Released September 2014, the LG G3 Vigor is smaller and cheaper than the LG G3.
Phone will or load pass beginning screen
My phone locked up on me, so I took the battery out. When I turned the phone back on it now won't load pass the beginning LG screen. How can I get it back on?
Add a comment
1 Answer
Chosen Solution
Try holding the power button and the volume down button . when you get the android use the volume buttons to scroll up or down and select boot normally then press the power button to select . This should allow the phone to boot normally. If this gives no joy then try resettng the phone to factory settings . Please understand that you will loose all data you have on the phone , contacts, photos ,music, apps will all be gone . It will be the same as when you first got the phone. Hope this helps
Score 2
Add a comment
Add your answer
Susan Sells will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 274
