The LG Optimus L7 P705 has a 4.3 inch LCD screen and weighs 4.3 ounces. It has a 5 megapixel camera and a LED flash. It houses 4 GB of internal memory with a SD slot that holds up to 32 GB of memory.
Why cant I receive txt message
why cant i receive txt messages
Add a comment
1 Answer
If you've checked all obvious stuff like you're not in airplane mode, sending to valid recipient, etc, I would check the APN codes for your carrier and make sure your device is set to correct codes. I have had this issue many times before with MetroPCS. You can find the correct APN for your carrier by searching Google or calling your carrier. HOPE that helps.
Add a comment
Add your answer
Bill Painter will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 189
