Model A1103 / 1.25, 1.33, 1.42, or 1.5 GHz G4 processor
My Mac Mini does not boot anymore.
After a power shortage my Mac Mini (A1103) does not boot anymore. I can hear the start sound and see a little folder symbol with a question mark in it. What can I do?
Score 1
Add a comment
Chosen Solution
The folder with the question mark means your system can't find a bootable system. The power fluctuation may have damaged the system. Try starting up from your system installation disk by inserting the disk and restarting holding down the "C" key. Go to the second screen pull down menu to Utilities -> Disk utility and repart the drive and repair the permissions. Now try to start up.
Score 2
5 Comments:
Thanks for the hint. Would that work also with the bluetooth keyboard or do I need to connect a USB keyboard?
by
For testing use the USB keyboard.
by
Unfortunately, it did not work neither with a bluetooth nor a USB keyboard. Or do I need to have a USB mouse, too?
by
If the USB keyboard is known to be good (please check it id you can), try it in all the USB ports. Yes you will need a mouse. If the keyboard fails you'll have to pull the hard drive to access it in an external enclosure or another Mac and you may have a damaged logic board, so make sure of the keyboard first.
by
good answer +
by
Add a comment
What do I do if the internal drive won't boot, but on booting the utility CD and going to Disk Utility,
I can see the drive, but the "Verify Disk Permissions" and "Repair Disk Permissions" buttons are
grayed out? The "Verify Disk" and "Repair Disk" buttons are useable, but they both simply run
through their checks and come up clean?
2 Comments:
Please copy and paste this into a new question. Thanks
by
Just to shed a bit more light on this issue (and this type of issue), having attempted to work on Mac Minis myself in the past, I find that it is extremely difficult to get to and replace the internal hard disk (which is what seems to have failed here).
So instead, I have been successful in adding an external hard drive (using "form-factor-friendly" cases (i.e. same footprint as the Mac, and sits comfortably either on top of or underneath the Mini). So just changing the boot device selection in the Mac "BIOS" (startup disk selection) allows you to easily boot from the alternate drive.
Mac still good, system up, internal hard disk irrelevant now.
by
Add a comment
Add your answer
Claas Carsten Kohl will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 13
All Time: 5,442
