Up to 20% off select tools
The DVP-SR200P is a Sony DVD player that can play DVD's or CD's and that has four buttons on the front of the device. It is no longer manufactured by Sony.
The draw will not open.
Why doesn't the DVD draw open?
Add a comment
1 Answer
Chosen Solution
@gembka ,Tim, if newer and under warranty and none of the listed fixes work, return device for repair/replacement/refund. Try resetting the player, shut off player, unplug for a minute, plug back in and try. Found some more procedures below from Sony forum for you to try, check the link below. Good luck.
If out of warranty and none of the procedures worked, you may have to remove outer case and see if DVD is jamming the drawer from operating,
I hope this helped you out, if so let me know by pressing the helpful button and tell us which button combination worked for you.
https://community.sony.com/t5/Home-Theat...
Score 2
Add a comment
Add your answer
tim will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 19
All Time: 571
