Up to 20% off select tools
A digital SLR camera by Nikon released in 2007.
hello . error nikon d40x
when i press the shutter button
camera says
"error . press shutter releace button again"
Add a comment
1 Answer
* First, Remove Its Battery.
  • Remove the Bottom Base Cover Plate
  • Removed All Screw Holding the Base Cover
  • Proceed Removing All Screws in a Sysmetic Clockwise Order
  • Remove All Screws and Aside It on a Piece of Tissue Paper
  • View of the D40 DSLR Base With Cover Removed.
  • The Gear Operating the Shutter
  • Lightly Move the Gear & Inspect for Contamination
  • A Closer View of the Gear Seen Through a Magnifying Glass
  • Repeat About 5 Cycles.
  • Apply New Grease Between Gears
* Spray a Little at a Time & Move Th Gears
  • Move the Gears 5 Cycles to Spread Out Grease
* Insert Battery & Test Before Closing Up Cover.
  • Close Back Base Cover & Have Fun!
If you want to watch all these instruction with images then open Nikon D40 Manual.
Add a comment
Add your answer
dionysis vatos will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 38
All Time: 658
