The Garmin Nuvi 255W is a GPS (Global Positioning System).
Is looping on Starr up
When I switch it on garmin logo appear then it stays on for a minute or two then it's switch off then on again but it don't start the maps
Add a comment
Chosen Solution
Most likely an OS error try updating your nuvi using the Software listed on there website.
Score 2
2 Comments:
My pc can't pick up garmin at awl
by
So just to be clear you have the software on your PC?
If yes Then do a manual reset there should be a small hole somewhere on the nuvi it self as Jayeff states in his post do that then try connecting to your PC
by
Add a comment
Hi,
Have you tried resetting it?
There is either a reset button on the bottom (it may be hidden by a sticker) or if it is not there then try sliding the power button on/off across and holding it for 8 seconds to see if this resets the device.
If neither of these work, try clearing the User data in the device by holding your finger on the lower-right corner of the Nüvi screen while turning it on. Keep your finger pressed until the pop-up window appears. Touch yes. All original settings will be restored. Be aware that any items that you have saved will be erased.
Score 2
Add a comment
Add your answer
Frederick Scheepers will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 898
