Model M8407 / 550 or 667 MHz G4 processor
How do you fix the Clock reset problem?
I need to reset the clock after each power-down.
I am sure I need a pram battery, just not sure which one:
The 3v lith coin cell, or the:
The G4 Titanium Mercury PRAM Battery @ $39.95
Product code: IF121-017-1
Apple Part #: 922-436
Do I need to open up the case to see which one?
Thank you.
DC
Score -1
Add a comment
Chosen Solution
Your PRAM battery needs to be replaced. It appears to be part number 922-5205 for the PB G4/DVI 667. Here's Apple's guide on which battery you need: http://support.apple.com/kb/ht2295
Score 2
Add a comment
You must know
the exact specifications of your PowerBook.
PowerBook G4 (15-inch FW800) & PowerBook G4 (15-inch 1.5/1.33GHz) 922-6007
PowerBook G4 (15-inch 1.67/1.5GHz) 922-6714
Powerbook G4 (15-inch Double-Layer SD) 922-7173
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Score 1
Add a comment
Add your answer
Crocdog will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 28
All Time: 1,971
