The first generation Audi A4 debuted in October 1994. The 1995-2001 A4 was built on the Volkswagen B5 platform.
dashbord is not working
hi
i have an audi A4 1996 , suddenly the rpm , speedometer , temperature , gaz level and all other indicator was disappear , but the car steel running ,
any idea why this is happen ?
Add a comment
Chosen Solution
Hi,
Have you checked in the fuse panel, that the fuse for the instrument cluster is OK?
Here is a link which shows the fuse box location and the allocation of the fuses. The fuse marked as Fuse #5 "Control unit for Instrument Cluster is the one you have to locate.
If you replace the fuse and it 'blows' immediately or shortly after, there is a problem and it should be checked out by either an auto electrician or an Audi dealer to find the cause..
It may be also have been simply that the fuse has simply failed. There are a few causes: fatigue due to age,mechanical failure of the fuse due to vibration etc.
https://www.manualslib.com/manual/396576...
Score 1
Add a comment
Audi Dashboard Warning Lights: Their Significance and How to Respond
Add a comment
Add your answer
elie will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 51
All Time: 8,993
