The Acer Iconia Tab 8 A1-840 is an 8" Android wi-fi tablet with 16GB of flash memory and 2GB of RAM. Acer released the Iconia Tab 8 A1-840 in 2014.
Tablet works but screen is black
My tablet is working I can hear my music playing through my head phones. But the screen stays black when I press the power button I can barely see the screen light up showing that it is on. Help please. Before the screen went black it was glitching out
2 Comments
If your screen isn't broken it may just be a loose connection, I assume that it is built the same way as the A1-830 so you should be able to pry the back off and check the connection. If this doesn't work then you will likely need a new screen to test/replace the current one.
by
It doesn't display. It just lights up. When i turn it on it turns on it vibrates but the acer logo doesn't show up nothing shows up except the light up. If you can find a video on how to take the back off
by
Add a comment
1 Answer
Chosen Solution
Ashana, The link below is for trouble shooting your device, hope it helps. Good luck.
You can also do a google search using your devices info to see how to remove back to check connections as Hortman recommends. I hope this helped you out, if so let me know by pressing the helpful button.
Acer Iconia Tab 8 A1-840 Troubleshooting
Score 2
3 Comments:
I can't find video. If you can please link it
by
Ashana Frank, here are vids. showing Acer Iconia A1-810 Screen Replacement - Resassembly, I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=I18JtQXD...
https://www.youtube.com/watch?v=eNb4eSZT...
by
Mine is iconia w 810 its full charge if you turn it on the acer logo will come out then it will be gone and the light will remain until the battery drain then i will charge again if i turn it on same thing happen repeatedly any help in this case
by
Add a comment
Add your answer
Ashana Frank will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 7,696
