Linksys EA9200 is a tri-band router that is capable of providing up to 3.2 Gbps wireless speed. Has 1GHz CPU to quickly processor all network activities and request. Has 4 Gigabit ethernet connection ports and 2 USB ports (one is USB 3.0). Is compatiable with Linksys Smart WIFI Application for smart devices. Operates on high data traffic on 5GHz band and lower traffic on 2.4 GHz band.
My USB port stopped working
My USB port has stopped working is there any way that I can fix it?
Score 1
Add a comment
1 Answer
Chosen Solution
You may need to replace the USB port. This is fairly easy to do. It is soldered onto the circuit board with 6 contact pins. If you do not know how to solder iFixit has a great guide here. How To Solder and Desolder Connections
Make sure the soldering iron reaches temperatures higher than 300 degrees Fahrenheit. Hope everything works well for you.
Score 1
Add a comment
Add your answer
Shane Davis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 336
