Up to 20% off select tools
Linksys EA9200 is a tri-band router that is capable of providing up to 3.2 Gbps wireless speed. Has 1GHz CPU to quickly processor all network activities and request. Has 4 Gigabit ethernet connection ports and 2 USB ports (one is USB 3.0). Is compatiable with Linksys Smart WIFI Application for smart devices. Operates on high data traffic on 5GHz band and lower traffic on 2.4 GHz band.
One external broken antenna
When I was setting up the device one of my antenna broke, Is it possible that the router works like that, or do I need to replace the antenna?
Add a comment
Chosen Solution
Hi,
Where exactly is it broken?
Has the connector port on the top of the router been broken or just the antenna itself?
If it is the port connector then there may possibly be more damage inside the unit.
If it is just the antenna that has broken and not the connector port, then it depends on which antenna has been affected. I think that there is 1 antenna for the 2.4GHz band and 2 antennae for the 5GHZ band, but I do not know which is which. You will most probably experience connection problems, drop outs, reduced range etc. It may be best to contact Linksys support to get information regarding which antenna has been affected and whether replacements are available. Here is a link http://www.linksys.com/us/support-articl...
Score 2
Add a comment
It looks like 2 of your antennas are for the 5 GHz operation and the other for standard 2.4 GHz. So depending of which one is broken the router should function normally. If this is a office setting with multiple floors and you are actually using the 5G quite a bit you may experience a smaller coverage area. The 5G will penetrate thicker walls but not go quite as far as the 2G .
Score 1
Add a comment
Upgradeable antennas mean you may not have to buy a whole new box to get better Wi-Fi. The antennas should deliver a significant bump in horizontal range, but if you’re having difficulty reaching a wireless client (a smart TV, a streaming box, a laptop, or what have you) on a floor above or below the router, you’d be better off with a power-line range extender or stringing ethernet to a wired access point.If you need right help then connect linksys team by clicking http://www.linksysroutersupport247.com/
Add a comment
Add your answer
wendy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 45
All Time: 10,473
